Starting Problems.......Eliminate Security System?
Can the BCM be bypassed or eliminated?
I did the Vats key bypass.......you don't need a chipped key to start car anymore.
When the car won't start. you leave the key on for 7 minutes and then the car starts.
nope gotta have the bcm. found this
You can just ground the yellow with black wire at the starter relay and the starter will work normally without any problem from the VATS system. The yellow with black wire is the starter relay coil ground wire which goes to the BCM. The BCM decides whether to provide the ground based on the VATS system. Grounding the wire at the relay just eliminates the BCM from the circuit.
Wow, funny that so many are having this same issue at one time -- perhaps it's a heat related failure trigger? Or just use/age? I dunno... Ghosts in the machine. HAHA
Ah, the joys of having a 4th Gen... Legendary GM quality control.
my 95 z28 is doing the same thing. everything works but dont turn over, when it was running it didnt have any lights on, and now that it dont turn over the security light blinks when the key is turned on. i had replaced the lock cylinder and had 2 keys made from the dealer last year, both keys dont work.
