Starting problems
RE: Starting problems
May not be holding fuel pressure when not running. Try priming the FI system, by turning the key on & off several times before cranking engine. If engine start OK after that,there isa pressure leak which could be caused by a bad fuel pump, bad regulator, a leaky injector, or an actual fuel leak.
