Starting Issue!!!!! Please Help!
Ok My car is a 97 V6 camaro with a fairly new motor in it. Late last week I noticed my car not starting on the first turn of the key like it usually does. It slow kept getting worse like it would take 3 or four turns of the key and some wiggles of the battery cables. Then it went to only starting with a jump, so I checked the battery cable and the negative battery cable was melted a little so the copper wasn't making a good connection so I cleaned it and made sure it was making a good connection. I thought it was the vats so I bypassed the vats and the car only started with a jump again, but after a jump it seems to hold a charge for a period of time where it will start under it's own power. The other day it lasted for a about 7 hours but over night it died and need a jump again. I had the battery checked and it was ok . I then took had the alternator checked it was ok. Now I don't know where to go. I can her the starter working and I drive the car fine after it's started. Any help is much appreciated.
Thanks chris
Thanks chris
Well I talked to the guy that put my motor in today. From the description I gave him he said it was probably my starter. I will let you either know later today or tomorrow afternoon. After sitting down and actually thinking about the problems that I have been having it makes since to me that it be the starter.
