Starter removal on a 97 Camaro 3.8
I can't remove the 2nd bolt on the starter because the 5/8" socket won't go on the bolt - the flywheel cover is very close to the bolt and the socket won't go on. Any idea how I can get that socket on the bolt ?
Ya you have to remove the sheild first. On bolt is short and easy the other you need a deep socket and a breaker bar. I did it with out but I used my feet to push it to crack it loose. Also I thought they were 12 mm bolts? That's what my car had...
