Starter motor advice
Old Apr 24, 2018 | 05:57 PM
leighm's Avatar
Default Starter motor advice
Hi Everyone, I have a 1994 3.4L auto camaro, I am in Australia and can't get parts locally. The starter motor in the car was incorrect and was only meshing on the very edge of the flexplate - I ordered a new one from rockauto and they do not distinguish between any variants in the model, so by my understanding there is only one type of starter motor, however the new one has the same problem - when it throws out only the last 1/8th of an inch reaches the flexplate, and the gear on this one is smaller than the gear on the other (also wrong) starter motor. Can anyone shed some light for me?
Old Apr 25, 2018 | 02:20 PM
95 camaro 406's Avatar
that is a tough one ebay usa $42.00 part # 900073-6442 seems to fit both the 3,4l an 5.7l .could be wrong on this .the 3.4l is geting harder to find some parts ,not the starter ,but i would wonder if they are the same ,try ebay though under 94 camaro 3.4l say that part# fits that an the lt1 as well as the caprice with lt1 for that year,
i allways had bad luck with rock auto .like that they did not have the part ,an there lay out hard to move around there site.somone else should be able to confirm if there the same or not
looked at couple sellers there an seem they fit many Gm cars from 94 an 95 roadmaster impala camaro 3.4l
Old Apr 25, 2018 | 02:49 PM
Are there shim(s) installed? Is the flywheel worn? If your too loose and there are no shims Flywheel could be shoot.
BlackBerlinetta
82-92 V8 Tech
Sep 14, 2012 08:51 PM
GaryLum
Nov 9, 2011 11:43 PM
ace2004
Nov 27, 2009 10:48 PM
wowcow
Mar 16, 2009 08:36 PM
siancell
Jan 30, 2006 11:49 PM
