Squeaking
Old Sep 4, 2008 | 10:43 PM
GMDCAMARO's Avatar
Default Squeaking
I have loud Squeaking from front two tires everytime i make a left turn over 20 mph.
I just replaced the rotors and pads with the SSBC Big Brake kit. We took a look at the pads, and im pretty sure they were not put in backwards.
Could it be a wheel bearing?
Any ideas would be great!
Car has 104,xxx
Old Sep 5, 2008 | 01:30 PM
Nessy's Avatar
Default RE: Squeaking
Possibilities:
(1)Need an alignment
(2)air pressure is low
after you check those:
It might be the belt that drives the power steering pump thats squaling. It may be lose or broken, so may need to be tightened or replaced.
See if those work
Old Sep 5, 2008 | 03:31 PM
tasinsc's Avatar
are the calipers touching the rims??
iLL95
Oct 5, 2011 02:41 PM
MaVeN
Apr 24, 2011 02:48 AM
alilaw
Oct 24, 2008 12:54 PM
jurmy2
Oct 12, 2008 03:47 PM
Bubonic
Oct 14, 2006 12:11 AM
