Spark Plug Heat Shields
Old May 21, 2011 | 08:50 PM
REN's Avatar
REN
Default Spark Plug Heat Shields
Found out my heat shields are gone on my V6, Is it worth getting new ones, Should I get them for all six or just the ones close to the manifolds?
Old May 21, 2011 | 10:32 PM
RFxCamaro's Avatar
Never knew they had em. Do you have a 3.8 or 3.4
Old May 22, 2011 | 01:27 PM
Tom70's Avatar
It's just a small piece of plastic that wraps around the wire, sort of like with your electrical wiring. It's there to prevent the rubber on your wires from melting when the engine gets hot. I would replace them because they should be cheap and it could extend the life of your plug wires.
Old May 22, 2011 | 08:06 PM
REN's Avatar
REN
I could have sworn I had metal covers on, the one melted on the passenger side may buy a couple and put them on. Just curious if anyone else has metal ones.
My car is a 3.8L
Old May 22, 2011 | 08:14 PM
blackz87's Avatar
LT1 V8's had 90 deg metal sparkplug shields. I boiught a set to use on my plugs when I installed headers. They do work.
t
Old May 27, 2011 | 11:52 PM
libertyforall1776's Avatar
I have them, and they are metal, but removed them when a GM shop tech recommended removing them due to issues (forgot the specifics now, but posted the reason on this forum about a year ago).
Since removal (over a year now), I have had no melting issues with the MSD 8.5mm wires that went on with Denso plugs at the time.
Yooper Z28
Nov 13, 2011 07:57 AM
fastb
Sep 18, 2011 07:45 AM
libertyforall1776
Jun 14, 2009 10:15 PM
