"Some damage"
Old Apr 26, 2009 | 05:11 AM
Persh's Avatar
Default "Some damage"
Who wants to tell me how fun this is going to be to fix?
The previous owners apparently let it sit (in a leaky garage) since 07 when their daughter slid into a ditch/****** wire fence.
It has an array of problems I BET IT'LL BE FUN
Old Apr 26, 2009 | 03:22 PM
greenarrow's Avatar
September 2009 ROTM
A good paint shop should have no problem fixing the paint for ya. If you're doing it yourself, still doesn't look all that bad. Might be a good time to get a cowl/SS/Ultra Z hood.
Old Apr 26, 2009 | 03:51 PM
Persh's Avatar
What do you use to reattach these? I've had a lot of different answers and I'm not really sure.
Is there any reason other then age both window motors would be burnt out? Looking through the receipts they were both replaced just a few years ago.
Finally, why would pushing and releasing the break cause the lights to flicker?
Old Apr 26, 2009 | 04:02 PM
greenarrow's Avatar
September 2009 ROTM
I'm a little confused what you're trying to reattach, I don't see anything to reattach in the picture?
For the window motors, it could be a number of things. Either they were just used up, or they sit so long something just went out, would be a good idea to check to make sure they are getting power before you go replacing them.
For the head lights, is this with the engine running or off. If it's with it off, then the battery might be low. Other than that, I don't know.
Just keep posting and eventually you'll get some other people in here to help.
Old Apr 26, 2009 | 04:17 PM
Persh's Avatar
Look at the bottom of the picture.. A seal thing is hanging loose.
Old Apr 26, 2009 | 04:21 PM
greenarrow's Avatar
September 2009 ROTM
Ok, yeah those are just put on with 2 sided tape, either some of that, or some RTV or silicone will fix it. I've had better luck with 2 sided tape on those.
Old Apr 26, 2009 | 07:29 PM
Persh's Avatar
Oh rust.
Old Apr 26, 2009 | 08:12 PM
SpecterGT260's Avatar
Ninja Administrator
do u currently own the car? I dont know if i would have bought it unless it was a steal
Old Apr 26, 2009 | 08:14 PM
Persh's Avatar
It was a little under $500... Seemed like enough of a steal.
Thought this failed recording for a friend was funny enough to post:
http://www.youtube.com/watch?v=ZCGPzoUeCDQ
The camera I used only records in 8bit 80kb/s audio, so it ended up sounding like a big lawnmower
Old Apr 27, 2009 | 12:51 AM
Persh's Avatar
Does anyone have any advice on what I should do about the rust? I've never dealt with it myself before, would I be better off paying someone to look at it/can I do that etc
libertyforall1776
Apr 5, 2014 09:14 AM
AmericanMuscle1989
Jun 25, 2013 10:38 AM
