Slipping gears maybe?
Old Nov 3, 2008 | 09:43 PM
MidnightLS1's Avatar
Default Slipping gears maybe?
Whenever i am in third gear and i stay there for awhile, when i go to accelerate the car acts like its in neutral. It will sometimes do this in fourth as well. But if i shift into neutral and then back into drive, it will go away, but it does this quite often. Any advice will help.Thanks Guys, by the way its an 02 Z automatic.
Old Nov 3, 2008 | 09:49 PM
Saint_Ali's Avatar
Default RE: Slipping gears maybe?
when was the last time the fluid and filter was changed ?
Old Nov 3, 2008 | 09:55 PM
SpecterGT260's Avatar
Ninja Administrator
sounds like low fluid to me. look for a leak. if no leak is found change fluid.
the tranny filter must be an automatic thing.......... black magic as far as I am concerned...... all this hocus pocus... little midget running around in there changing gears for u......
Old Nov 4, 2008 | 05:11 PM
I drained the fluid about 3 months ago, but i didnt replace the filter. How hard is it to replace the transmission filter? Any good sites for steps?
Old Nov 4, 2008 | 05:21 PM
Saint_Ali's Avatar
when you drop the pan you will see the black fliter right there, it just pops in and out, not hard at all.the filter is as important as changing the fluid
TheGrimReaper73's Avatar
is there anyway it could be the bands around the transmission? my truck does the same thing.. and that is what the problem is i believe.. or i just need a whole brand new transmission
Old Nov 5, 2008 | 07:54 AM
Can transmission fluid be added to the existing fluid if it is low, or does it have to be drained first? How hard is removing the pan?
Old Nov 5, 2008 | 08:56 AM
I did have to replace the rear main seal 6 months ago for a leak, but its not leaking now..
Old Nov 5, 2008 | 11:24 AM
Fluid is fine, torque converter maybe?
Old Nov 19, 2008 | 04:13 PM
libertyforall1776's Avatar
Check the shifter linkage I had a problem with mine that gave similar problems on my '95 3.4L Auto.
Also, when you are cruising the highway, does it reliable stay in the downshifted gear? Also, when you gun it while already moving, does it have trouble engaging, like it takes longer and does not feel right? If so, it's probably bands/clutches in the Trans., as happened to me twice in my '01 SS Auto. I also had a strong whirring sound from the rear-end which turned out to be worn gears...
Greg08
Jun 18, 2012 07:24 PM
YoungDriver
Sep 3, 2009 09:37 PM
neva_aquainted
Aug 18, 2008 11:28 AM
02blackonblack
Apr 14, 2007 05:21 PM
hotrod
Aug 1, 2006 06:13 PM
