Should i Cam my v6 or do LS swap ??
Old 11-28-2016, 04:27 PM
95 camaro 406's Avatar
i no some guys with mustangs that get real crapy gas mileage with 4,10s ,i just feel like unless your raceing no need for 4.10,my gas milage is bad as it is ,3,23 or 3.42 will be fine with the stronger gears,couse my existing 28 spline gear i think is getting worn ,not only that it has 105000 miles on it.an some pounding it has took its toll too but still holding up well ,i need to do that strenghtening the 10 bolt sticky for alot less then a 12 bolt ,its hard to drive it like grams car i have heard a few clanks ,but fine the sweet spot seems pretty good for a worn out gu2 mostly from first to second gear when i forget to shift grabs hard wich is good but could break something sooner or later i think
  #42
Old 12-01-2016, 01:03 PM
Maro_Boy98's Avatar
Originally Posted by kevins88ss
After we did the 3.4 to 3800 swap, we had 4.10 gears installed in our 94 rear and it really made a difference. Well worth the $350 for the gears and have the shop install them. Top end suffers but every gear pulls harder. Now I wish we had done a posi unit.
Just had car towed to my mechanic car should be back rolling in no time
  #43
Old 12-03-2016, 03:27 PM
sounds good
  #44
Old 01-09-2017, 10:13 AM
kevins88ss's Avatar
Keep us posted! If you're doing the 4.10's I know you'll love the difference.
Chaos99
09-09-2011 11:42 PM
fitzm
10-10-2010 08:46 PM
slvrblt2
07-30-2009 10:26 PM
mcampbellga
03-03-2009 11:09 AM
Quick Reply: Should i Cam my v6 or do LS swap ??
