the shifting cable. transmision
You prolly got the arm on the trans on backwards. that would reverse all your settings.
As far as replacing the cable you would need to remove the console and shifter, then the cable were it goes through the floor and after that feed it out the rest of the way. IT has a few brackets here and there to hold it where needed and you need to make sure you dont damage them since the new cable will need them to mount properly.
It is a time consuming job but not a hard one.
Massey
