SeaFoam
Old 11-13-2007, 04:17 AM
Spartan66's Avatar
Default RE: SeaFoam
ok! lol, sounds like fun in my opinion!
Old 11-15-2007, 08:08 AM
whammer3024's Avatar
ROTM Winner
Default RE: SeaFoam
don't know if you guys knew this or not but sea foam and deep creep are actually the exact same formula...deep creep is just in spray form
Old 11-15-2007, 04:35 PM
Denhsturrr's Avatar
Default RE: SeaFoam
would you need to do a tune-up after pouring it into the vacuum line?
Old 11-15-2007, 06:30 PM
02StanGT's Avatar
Default RE: SeaFoam
I don't think you NEED one, as it cleans the crap out of the cylinder, which should include the spark plugs...
Old 11-15-2007, 06:32 PM
aleksandr's Avatar
Default RE: SeaFoam
No you wouldn't.
I did mine yesterday and there is a noticable difference. A quicker throttle responce is the most obvious. What was surprising though is that car didn't smoke at all when I was pouring it into the vacuum line and after it. I've only done 1500 miles on it since I bought it so I suspect the previous owner sea foamed it before selling.
Old 05-27-2008, 09:48 AM
maguilar496's Avatar
Default RE: SeaFoam
Can I add it to the evap vacuum lineon the intake?
THank you
Old 05-27-2008, 10:20 AM
MusicMan's Avatar
The Jazz Man
Default RE: SeaFoam
it's alive!
Old 05-30-2008, 12:03 AM
98SS#689's Avatar
Default RE: SeaFoam
ORIGINAL: maguilar496
THank you
Use your brake booster line instead, the evap line is kind of small as opposed to the brake booster line.
Keep in mind, you won't gain any horsepower or torque from using Seafoam, only getting back to close what your engine originally had from the factory.
Using it in your intake cleans out carbon, in your gas cleans your injectors, in your oil cleans out the build up of any sludge.
PedroRider310
02-27-2012 08:56 AM
Mikey.
08-22-2011 12:03 PM
Fterr99ss
LS Series Tech
12
12-05-2009 01:55 PM
BLACKJACK
12-15-2008 08:19 PM
94CamaroSFI
01-30-2007 05:18 PM
Quick Reply: SeaFoam
