seafoam!?!?
Old Dec 15, 2008 | 11:40 AM
BLACKJACK's Avatar
Default seafoam!?!?
anybody know what seafoam is and what it douse? i heard its good for cleaning you motor but is it worth it?
Old Dec 15, 2008 | 04:35 PM
Default RE: seafoam!?!?
It will douse anything you pour it on, but probably won't put out a fire because it has a petroleum base. lol
Also makes a lot of smoke when used to clean the inside of the engine. Looks impressive, but like most stuff in a can won't really fix anything permanently.
Old Dec 15, 2008 | 05:37 PM
BLACKJACK's Avatar
oh ok..i heard some guys at work talking about seafoamin there car soon...i also heard it stinks too\ lol
Old Dec 15, 2008 | 07:25 PM
c4maro's Avatar
Ive heard its great and its terriable. Some people say it stoped clicks and stuck parts in there engines, and others say it destroyed there engines. Personally, i wouldent take the chance. I suggest putting 2 cups of automatic transmission fluid into your motor. It cleans stuff out really good, then replace the oil after a good drive.
Old Dec 15, 2008 | 08:11 PM
BLACKJACK's Avatar
ok my z has only 67,*** miles on the motor but i want to keep it in perfecto runing order so ill try that after my next oil change
Old Dec 15, 2008 | 08:19 PM
cbr600rx7's Avatar
Its good for cleaning out vacuum lines and things related to them. For best results you need to use a half bottle in your fuel tank and about half in your vacuum lines. I also like to use about half a bottle in my oil every 10,000 miles or so right before i change my oil. I will add it to the crank case and let the car run for a few minuets then turn her off and drain the oil. I have had it correct miner issue's in the past and you will notice a difference in older vehicles that have not been cleaned up in some time.
PedroRider310
Feb 27, 2012 08:56 AM
Mikey.
Aug 22, 2011 12:03 PM
Fterr99ss
LS Series Tech
12
Dec 5, 2009 01:55 PM
aleksandr
May 30, 2008 12:03 AM
94CamaroSFI
Jan 30, 2007 05:18 PM
