running to rich on my 94 z28
Many times what appears to be a rich mixture is the result of misfire, where raw fuel is being dumped into the exhaust system. The PCM is seldom the cause of problems, but sensors and wiring are.
Neeed to do some diagnosing such as:
CEL lit or flashing?
Spark plug inspection
Fuel pressure test
Check injectors with NOID lamps and make sure they are pulsing and not staying on all the time (grounded control lead)
Check all sensor outputs with a scan tool and verify that they are telling the truth. The PCM cannot detect a sensor that is sending out garbage info.
Fuel pressure test
if you plan on keeping the 94 it may be better to invest in a scanner that will work for you. 94 is an unusuall setup and not all obd1 scanners will work on it. check the 02 sensor connections and wires for damage, also take em out and see if there fouled. test your evap system including the gas cap, test your temp sensors. coolant and intake air. shbox is good check it out. http://shbox.com/1/4th_gen_tech1.htm
i moved your thread to the 4th gen section. welcome to the forum, enjoy.
What would be the best scanner to buy and where to get it? I plan on getting a new engine next year. I want another LT1 to go in but have it built as much as possible! Ahaha You know chasing that horsepower!! This is my wifes car but she likes the power as much as I do! h loves busting the ricers around here! They think because she a woman that she scared to punch, well she's not!
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
