Right turn signal not blinking.
Alright, so since day one (when I got the Camaro on March 29th) the front right turn signal doesn'tblink. It will be on with the DRL, but once you put on that turn signal, it's just off...no light. I've tried replacing the bulb (figuring that would have fixed it since my rear turn signal didn't work, instead it would just stay on and replacing that bulb seemed to work) and still no blinking. When replacing the bulb, I noticed that the...socket (?) seemed a bit charred and when I pulled out the old bulb, it came out like coal.
RE: Right turn signal not blinking.
ORIGINAL: Intrepid781
I have this exact same problem even on the same side. I replaced all the bulbs and it still does it. Does no one know what could be going on?
Your turn signals were blinking without the flasher? I'm not sure exactly what you're saying. There are two flashers: One for the hazards, and one for the turn signals. The lights will still blink if you use the hazards with the signal flasher removed, and vise versa.
