Reverse problems
Old Mar 7, 2008 | 08:47 AM
xavier21282's Avatar
Default Reverse problems
Ok here is my problem i have a 1995 5 speed 3.4L v6 1st gear through 5th gear work fine. Reverse will go in but grinds like it is not in all the way i asked my mechanic what to do and he told me to find the bleeder valve on the slave cylinder and bleed the system. But i have looked all over that cylinder there is not one please help me anyone. I still owe $1400.00 on this car...Josh
Old Mar 7, 2008 | 01:17 PM
baseballer91's Avatar
Default RE: Reverse problems
a lot of people have trouble with their sticks, like there was a post a cvouple days about this same exact thing (cept he was a 6spd)
i had that problem too but it just went away...
Old Mar 8, 2008 | 11:45 AM
buddywackos's Avatar
i always made it a habit to put it in first gear then shift to reverse. if i don't thenreverse grinds sometiems as it goes in.even with the new transmission i had installed a couple weeks ago. this is only my second manual vehicle, maybe they're all like that?
Old Mar 8, 2008 | 12:46 PM
It sounds like your mechanic is suggesting that your clutch isn't disengaging fully. If that was the case, I would expect you to be crunching the gears in first as well. I've had a similar experience before,on adifferent car. Has the oil in the tranny ever been changed? The old oil could be the problem. Also, with a higher mileage trans, you maywant to step up to a slightly thicker viscosity oil to help keep the sloppier internalsfrom free-wheeling as easily after you depress the clutch pedal.
Old Mar 8, 2008 | 12:51 PM
CMRO GRL's Avatar
May 2008 ROTM
ORIGINAL: buddywackos
mines like that, you pretty much have to go to first 1st then put it in reverse. My first manual was like that too....
Old Mar 8, 2008 | 12:57 PM
ORIGINAL: CMRO GRL
glad i'm not the only one, didn't want to sound like an idiot lol
Old Mar 8, 2008 | 01:03 PM
CMRO GRL's Avatar
May 2008 ROTM
i mean, you dont HAVE to go to 1st first, but it usually grinds if you dont, at least in my car and past car
Old Mar 8, 2008 | 01:15 PM
yea, i can get it in without 1st, but i'd prefer it not to grind. it's weird because if i try to slowly put it in reverse it will grind. i can raise the shifter towards neutral and the grinding will die away, then it goes in gear. ah, who cares, my car feels great again with the new transmission and slave cylinder lol. no more stupid whining, i hated that.
Old Mar 8, 2008 | 01:32 PM
andkrs7's Avatar
mine does the same...it grinds sometimes but not always. i try to put it in reverse before i turn it on if i can- like if i'm backing out of a parking space
numskull92
Apr 29, 2012 08:10 PM
bryans3.4 95
Oct 27, 2008 12:40 AM
69dmz
67-69 V8 Tech
Oct 19, 2008 09:26 PM
dorkpunch
Jun 29, 2008 08:54 PM
Slimbo
Jun 4, 2006 07:06 PM
