reverse glow guages
reverse glow guages
I am installing some white face guages on my 94 z-28. The guages came with a dimmer switch? the switch has a red wire and a black wire. I wanna know if i can splice into the original head light switch or dimmer wheel. if so what color wires on the original wiring harness do i splice into?
after stripping a small section of the wire for the wf gadges i just unpluged the headlight wire harness and fed the wire into the plug wire so it would get a conection and plugged the harness back in. i dont remember what color it was but it was the outlet wire for the dimmer wheel. if u need more info i can pull it apart and see.
