Replacement wiper arm trouble
Old Dec 13, 2010 | 06:57 PM
magicpigdetective's Avatar
Default Replacement wiper arm trouble
Hey guys,
I recently bought a 99 camaro and the passenger side wiper arm was snapped off. I didn't think this would be too big of a deal, but I can't seem to locate one. Not easily, anyway. I know I could probably go to a junkyard, but this holiday season is particularly busy for me. The closest I've found is for a 95 by Dorman. Would this fit my 99? thanks in advance
http://www.partstrain.com/store/deta...rb42570195wiar
Old Dec 13, 2010 | 07:25 PM
Buffalo02Z28's Avatar
Thats a weird looking wiper arm. I got replacement wiper arms for my 2002 Z28 from Sears.
Old Dec 13, 2010 | 08:08 PM
RedKnight's Avatar
Believe it or not, the arms are different on a '95 and a '99. First, the '95 has the plastic cover on it, and secondly, the hook at the end of the arm where the new blades attach is reversed on the two. The '95 hooks upward, and the '99 will hook downward. The arm should technically work, but it will be different.
Old Dec 14, 2010 | 08:19 AM
i totally believe that. so it should still work? not super concerned with aesthetic, i just need it to pass inspection, preferably before the holidays
Old Dec 14, 2010 | 02:12 PM
RedKnight's Avatar
I don't see any reason why it wouldn't. There's a '96 and a '99 in the driveway here, and other than the two differences I noted earlier, they look interchangeable. I took pics of each that I can post later in case it helps you out.
Old Dec 14, 2010 | 02:32 PM
the newer style will rub on the older style 4th gen. not sure if the oposite is a problem. here is a place with correct one. http://www.gmpartsgiant.com/componen...2m282fw87.html
windshield wiper arm (98-02), LH = 22154388
windshield wiper arm (98-02), RH = 22154389
Old Dec 14, 2010 | 03:17 PM
Massey's Avatar
Not only are the arms different but the posts are different too. If you use the newer arms on the older posts the arm will be angled wrong and will cause chattering. The updated nose also got different wiper posts.
The older arms will fit the newer "Catfish" cars but may not sit right on the glass. The plastic cowl parts are the same from the older cars to the catfish cars.
I found 2 GM direct type sites that can get them for you.
http://www.newgmparts.com/partlocato...layCatalogid=0
http://www.gm-parts-dealer.com/parts.htm
The second one you will have to do the search, the wiper arms are in the Windshield section.
Massey
Old Dec 14, 2010 | 08:16 PM
Wow, thanks guys! huge help
Old Dec 14, 2010 | 08:25 PM
RedKnight's Avatar
Thanks, gang. I wasn't 100% sure. They looked about the same at first glance, but apparently are much more different that I thought. Me = d'oh!
Buzcutnj
Aug 30, 2014 01:32 AM
CFallsGuy
Feb 29, 2012 04:12 PM
cord0711
Jun 25, 2011 05:21 PM
A-ron
Mar 28, 2009 11:02 PM
Big Bob
Sep 10, 2006 12:35 PM
