replace turn signal
You have to go at it from beneath the car. Remove all the plastic shield and access it that way. Or I have heard on the 1998+ you can access it by removing the headlight. You may have to wait more than 5 minutes for someone to post... Not everyone is up right now.
i replaced the front turn signal bulb on my 2002 SS from the engine bay. without removing the headlight or anything, its not that hard. its a really awkward hand placement, but it is do able. and remember, if im not mistaken there are 2 turn signal bulbs, and inner and an outer. the inner one haslike a boot ontop of it, and is installed vertically, to get that one out you just twist the boot towards the engine,the outer is installed horizontally.
