Removing the LT1
Old 03-20-2011, 02:34 PM
oh ok thats right you have a super camaro.. map or conection to it. test the evap to be sure. test fuel pressure. test thottle postion sensor. if you clear the ecm you will clear the codes. you can flash the codes on a 93 dont need a scanner.
http://www.shbox.com/1/dlc2.jpg
  #22
Old 03-20-2011, 09:28 PM
s_m_a38@yahoo.com's Avatar
Well we ended up getting the codes. Code 15 and code 26. We know code 15 is the coolant temp. sensor and code 26 is the Quad Driver module. But what we don't know is what the Quad driver module is. Any help on this one? Ha.
  #23
Old 03-21-2011, 12:00 AM
  #24
Old 03-26-2011, 08:42 AM
Thanks for the help Craby. As far as the quad driver module goes, is it okay to drive with it having problems? Or is it one of those things where it depends on exactly what it is?
  #25
Old 03-26-2011, 09:25 AM
hows it running? it may foul the plugs, other than that i dont think it will hurt anything else.
  #26
Old 03-26-2011, 10:07 AM
Well, it runs fine, when we can get it to start. The alternator is going bad, so I'm replacing that soon. But the plugs became fouled when we first started getting it running. I'll end up replacing them as soon as the title gets back.
allport35
07-08-2013 05:52 PM
borjawil
04-18-2012 06:52 PM
94.V6.VROOM
02-08-2010 08:13 PM
94z
06-26-2008 01:33 PM
Quick Reply: Removing the LT1
