Removing the intake
Old Feb 28, 2009 | 10:49 PM
kylehoff123's Avatar
Default Removing the intake
Hey,
I have an exaust leak at the manifold in the back where the headers are suppose to tighten down due to the fact that someone broke the two back bolts off. So i am taking the Intake Manifold out and the right valves and springs so i can remove the part and tap out the bolt. Does anyone know what i could do to clean the valves up or help make the car run better. It has 212,000 miles on it.
Old Mar 1, 2009 | 04:30 AM
cerbid's Avatar
more info on the car? year, model? v8 or v6? etc? pics?
Old Mar 1, 2009 | 05:03 AM
Spartan66's Avatar
That's irrelevant to cleaning the valves. If you don't have access to a parts washer you could use some carb cleaner, let it sit for a little bit, and then a brush to scrub off what the cleaner takes off.
Old Mar 1, 2009 | 01:00 PM
viciouZ's Avatar
Carb cleaner or seafoam it when you get it all buttoned up again.
Old Mar 1, 2009 | 02:46 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
There are several methods to do this. I am sure it needs to be done with high miles and no knowledge of previous owners. Seafom works good for somethings, it is used when the motor is together and running, another option is draining all the oil, replace with ATF, run for 20 minutes, drain, replace with full synthetic. The detergents in the ATF will clean it all out really well and the synthetic will keep it clean.
Another option is to get some large 'c' clamps or other locking device (large enough to fit over the entire head) and some 2x4's. PLace the heads upright, place the wood on eather side of the heads and clamp them down enough to open the valves. Soak in carb cleaner (or another good cleaner) for a few days, rince with hot water, coat with a good rust preventative penetrating fluid and re-install.
Old Mar 2, 2009 | 10:56 PM
Does it matter how long i have the heads off of the car while i am cleaning them as long as the engine is cover up ?
Old Mar 3, 2009 | 02:17 AM
SSV6's Avatar
replace the exhaust bearings problem solved lmao
Old Mar 3, 2009 | 06:24 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Correct. As long as the engine is covered and dry it doesnt matter. Dont forget to replace the lost coolant and oil once you get them back on.
duane18
Apr 28, 2020 03:39 PM
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
Drexg
Apr 14, 2011 10:28 PM
s_m_a38@yahoo.com
Mar 26, 2011 10:07 AM
