Rearend help
Old Jan 18, 2010 | 05:34 PM
DADZ28's Avatar
Default Rearend help
Can anyone tell me what axle a 1993 5.7 Z28 has? I want to order a pair of moser axles. They are listing two differant types. One with 3 abs ring and the other with 4. Any idea which one i need for my "93 ?
Old Jan 18, 2010 | 05:48 PM
DADZ28's Avatar
Nevermind, I found the answer to my own question. The 1993 has the 3 ring ABS axles. The four ring was introduced in 1994 as part of the traction control upgrade made available for v-8 cars.
Old Jan 18, 2010 | 05:49 PM
should be 3. two in the front and one in the back on the 93.
Old Jan 20, 2010 | 06:47 PM
DADZ28's Avatar
Cool
It took a little research to figure out what I was needing
to purchase. So far I have a little over $700.00 beefing up the
stock 10 bolt. Moser axles and stud kit, Richmond 3.73 R&P and mega install kit, T/A Girdle and a main bearing carrier bolt upgrade.
Nothin much done in the engine compartment. Bypassed the TB coolant hoses, K&N cold air kit, Jegs 10mm wires, AC Delco rapidfire plugs, MSD Blaster coil and AC delete.
So much money, so little time.
DiggityDavee
11
Jun 2, 2014 08:09 PM
gofastturnleft70
Feb 12, 2012 05:47 PM
1989fbody
Aug 15, 2009 04:35 PM
Racer111
Sep 8, 2007 01:48 PM
Chappie99
Jul 6, 2007 04:24 AM
