Rear Fog Light and Amber Turn Signals for German Registration
Old Feb 20, 2019 | 09:24 AM
Primus's Avatar
Default Rear Fog Light and Amber Turn Signals for German Registration
Hey Guss,
im New here. Im Max from germany and now own a 3.4L V6 manual from 95.
the car was owned by a Air Force soldier who sold it to me.
we have some regulations to get a car on the road.
And thats my problem.
i need to put a rear fog light in the back, that has a own switch and is only allowed to work when the lights are on. A bright LED Strip would work, but i still dont have an idea how to connect that.
Next, and the bigger problem, i Need amber turn signals that cant be connected to the brakelights. I have the US-Spec lights. How do i separate the brake/turn Signal to get two separate signals? Are there any bright amber LED bulbs that would shine through the red plastic?
Thank You in advance for your help
cheers
Old Feb 21, 2019 | 01:03 AM
see if you can find some tail lights from a 98-02 Camaro for the amber blinkers. the blinker and brake lights should already be separate bulbs, one is brake light and parking light other is the blinker.
Old Mar 13, 2019 | 11:24 AM
el-chupakabra's Avatar
Hey there.
Nice to see another guy from Europe here! You can find rear lights with amber turn signals on eBay.de. To do the wiring, you unfortunately have to contact
your local shop which specializes on car electrics and they will do all the wiring. Same for the fog lights. That is what I did after trying to do all by myself
Old Mar 14, 2019 | 08:50 AM
Primus's Avatar
Thanks for the Reply guys.
I found a way to do it. I routed a cable from the front ( to get the Turn Signal and Fog Lights) to the back, used the Bigger Clear Glass for the Turn Signals, the left smaller for the Rear Fog Light and the right smaller for the Back up lights. I got the Brake Signal from the third Brakelight. That was the easiest and most clean way to do it or Reverse it later if I want to.
Thanks for helping me out :-)
wlbuckles
May 2, 2015 09:26 AM
69 camaro guy
Apr 11, 2011 11:06 PM
bowtieguy92
Jan 11, 2011 10:42 AM
nitrojunkie
LS Series Tech
Mar 1, 2010 08:04 AM
SavageSix
Mar 21, 2007 10:02 PM
