rear end questions
Old Jan 8, 2008 | 11:08 PM
lt1z28's Avatar
Default rear end questions
okay i have a 96 z28 it is a fast car my best friend has a 94 and it has alot better take off after some research i found out his has the 3:23 rear end gears and mine has the 2:73 how hard would it be to put 3:23 in my car and would it mess with the speedo?
Old Jan 9, 2008 | 08:57 AM
whammer3024's Avatar
ROTM Winner
Default RE: rear end questions
if you're going to do a gear change you don't want to mess with 3:23. i just took mine out and went to a 3:42, but 3:73 is what most people recommend. rear end work can be expensive and a lot of mechanics don't do it. and yes it will mess with your speedometer. i'm about 8 mph off now
Old Jan 9, 2008 | 11:09 AM
You know, it would be a lot cheaper for you to sabotage your friends car instead!
Old Jan 9, 2008 | 02:11 PM
kaoss_11's Avatar
I want to go 4:10 for my street car. A buddy of mine went 3:73 and regrets it. he wishes he had gone 4:10
Old Jan 9, 2008 | 06:01 PM
biohazard's Avatar
Whammer is right if you are going to gear it o with a 3.73 or 4.10. I am going to go 4.10 in my 96. Hell I might go 4.30 lol!! Everytime I gear a car I wished I would have went bigger and most other people do too!
Old Jan 9, 2008 | 06:29 PM
95slvrZ28's Avatar
If you have an auto 4.10 is pretty steep for street applications. I'd suggest going for 3.73 if you're having custom rear end work done. You could also consider finding a wrecked six speed Camaro or Firebird in a junkyard and just completely swapping out your rear end, that way you'll have the 3.42 gears and you don't have to worry about the issues that you run into with new gears. As far as the speedo goes, you can have the PCM reprogrammed to accommodate the new gears since the car has an electronic speedo.
Old Jan 9, 2008 | 11:27 PM
lt1z28's Avatar
i can put them in my car at my school im training to be a mechanic and ive helped my teacher do it before so it wont be to bad expense wise. see i drive my car every day and probably around 50 miles a day i want a gear ratio that will help my launch alot harder but i still want to get reasonable gas millage
Old Jan 10, 2008 | 12:34 AM
95slvrZ28's Avatar
Don't get anything bigger than 3.73's then, you may want to go for the 3.42's if you drive that far every day.
Old Jan 10, 2008 | 02:54 AM
armynatguard18's Avatar
i clicked on this thread, expecting to talk about something other than gearing...i mean come on...what a misleading title lmao
Old Jan 10, 2008 | 11:16 AM
ROTM Winner
ORIGINAL: armynatguard18
now that was funny! anyway...i have 3:42's in my car though i haven't really driven it since the install because it's put away for the winter. it pulled harder i can tell you that. maybe you should be looking for a torque convertor...just an idea
