Rear end prep questions
Hey guys,
I have a couple of questions. I already introduced myself here
https://camaroforums.com/m_187951/tm.htm
I just picked up a 98 Z28 rear end as a replacement for the whining rear I have now..
Any suggestions on what I should do prior to bolting it up? Should I change the fluid? Is there anything specific I should inspect? I already plan on replacing bothu jointsand it is geting a new caliper/rotor setup. I don't like doing things twice so I would rather do it right the first time and what better way than to ask the experts...
Thanks in advance
Liquid1
Thanks in advance
Liquid1
RE: Rear end prep questions
Really? You think I should replace the ring and pinion? The rear is off of a 98 z28 and it had low miles 40-50k as far as I know. Any suggestions on where I should get the ring and pinion?
Any other suggestions?
greenarrow
04-22-2009 01:45 AM
