rear control arm bushings
Old 01-31-2010 | 11:07 AM
1989fbody's Avatar
Talking rear control arm bushings
i just put slp subframe connectors on my 95 z28 i hear this squeaking sound from right rear and i put my hand on the rear control arm and i can wiggle it on the left hand side i cant
i get under the right side and i see the bushing giving in every time i wiggle it so this is proably the contorl arm bushing bad
i would aprreciate everybodys input im thanks
Old 01-31-2010 | 11:47 AM
maudyZ28's Avatar
you shouldnt be able to wiggle it
if its a stock arm i would save up like $100 for some UMI, or BMR etc non-adjustable control arms with polybushings
Old 01-31-2010 | 11:56 AM
1989fbody's Avatar
i didnt think u should be able to wiggle it u can see thebushing giving in though so i think its a bad bushing so im just going to buy dome umi control arms , the bolts are tight
Old 01-31-2010 | 01:36 PM
libertyforall1776's Avatar
Check out these bushing bearings (2nd pic is stock vs Global West Del-A-Lum):
http://www.camarohomepage.com/project/part1.htm
"The Global West Del-A-Lum is really a bearing not a bushing. The blue aluminum shell is pressed into the control arm. The gold steel sleeve rides on the control arm shaft or bolt and is locked in place. The Delrin sleeve "floats" between the two. Layers of grease are between all the parts. Del-A-Lums are a better choice than polyurethane bushings because they never squeak, do not bind the suspension and have better durability. Image: Global West Suspension."
Attached Thumbnails rear control arm bushings-604.37.jpg   rear control arm bushings-604.37a.jpg
Old 01-31-2010 | 05:53 PM
maudyZ28's Avatar
^^^ but are $100 for a bush VS. $100 for a pair of control arms hahah
Old 01-31-2010 | 06:47 PM
the bearings are more sensitive to vibration transfer etc so ride comfort will suffer if u use a control arm with bearings on both ends. it is effective to use a bearing on the end furtherest from the rearend and a rubber bushing on the other.
Old 01-31-2010 | 07:43 PM
1989fbody's Avatar
thanks for all yalls input i think im going with the 100 umi bushing rear control arms , its just a daily driven street machine
voxeltoxin
07-12-2012 02:46 PM
BillsFan727
05-23-2012 08:47 PM
grabbem88
09-26-2011 03:12 PM
typeomang
07-01-2011 02:46 AM
mondego
01-02-2008 10:27 PM
