random squeeky noise under car
I keep hearing random squeeking noises from under the car and its noisey but then goes away...its not constant..I notice when i first back the car out and turn or when i first put it into drive and turn then go it squeeks a little...could a leaking power steering pump hose cause this or is it somewhere in the brakes? I just replaced my rotors and brake pads so Im hoping its not that..I noticed it does a high pitched squeel when i press the brake pedal and thats when i put my 20 inch wheels on...can you guys give me any advice on either of the squeeky problems?
no i didnt but i noticed that one rear drivers side pad was hard to get on cause the caliper wouldnt compress anymore i had to bang the pad in to make it fit and finally got it, do u think the caliper is bad? or if this could be the issue?
this dang penzoil add sucks. anyways if the sliders are not lubed and working correctly it can cause noise, if rotors are glazed it can cause noise, if pad compound or lube is not used it can cause noise
