quick lt1 question
Old Dec 31, 2007 | 11:07 PM
meteoralp45's Avatar
Default quick lt1 question
would the lt1 froma caprice fit in my camaro? are the lt1 in the camaro nd caprice the same?
Old Dec 31, 2007 | 11:11 PM
6v49der's Avatar
Default RE: quick lt1 question
buy an ls1, the lt1 will require alot of modification to fit in that car, check the forsale section of the forums someone in SC has an ls1 from a wrecked ss for sale, it looks like your close so go buy that instead, it would bolt right up
Old Jan 1, 2008 | 05:50 AM
Spartan66's Avatar
ORIGINAL: red94v6
im pretty sure u could find a camaro with the lt1 already installed for about the same price all that modding and installation would cost you.
Old Jan 1, 2008 | 12:40 PM
yeah, i would do ls1 if i could find one for a decent price or find one period, but i posted on that ad, but the reason i was askin is cause i found a lt1 out of a caprice for 400..so i didnt know if it would work
Old Jan 2, 2008 | 12:18 AM
Spartan66's Avatar
LS1 is nice, but i like my LT1.
Old Jan 2, 2008 | 06:47 PM
They are basically the same, except that the caprice LT1 uses iron heads and a cam ground for low end torque. The water pump has different angles for the hoses, the intake plumbing and exhaust manifolds are different.
Old Jan 3, 2008 | 04:00 PM
LT1RUNNER's Avatar
The Lt1 in the caprice is only rated at 260hp rather than 275hp in the Camaro?
blackbeauty1995
Mar 18, 2014 06:08 PM
gmman200
Mar 1, 2009 11:36 PM
sk8erdude36
Dec 12, 2008 06:48 AM
Celticsfan
Oct 9, 2006 02:01 AM
