Quick Heat Question
Old Oct 8, 2012 | 10:10 AM
cjgordon117's Avatar
Default Quick Heat Question
Ok so my heat is warm-ish but not hot like cars heaters usually are. I had a leaking heater hose not too long ago and i had the dealer fix that 4 me when they did the fuel pump. Im thinking air got into the heater core and i should bleed it . Should i use the regulart method in the how to thread except with the heat on or is there something special to be done? I've seen this fix the problem before but i just wamt to be sure. I have no over heating or coolant issues besides this. Oh wait i do have the low coolant light even though its full but i'll just unplug that. Thanks for uour suggeations!!
Old Oct 8, 2012 | 10:08 PM
what motor and year. the coolant runs through the heater core at all times. its the air thats regulated. there is a flow restrictor in one of the hoses and it can get plugged. look here and see if any of this helps. https://camaroforums.com/forum/lt1-l...84/#post587081 found in the general info and specs sticky found at the top of this section.
josh75camaro
Jan 7, 2010 09:09 PM
Clh6387
70-81 V8 Tech
Apr 7, 2009 10:21 PM
jttalus
Mar 10, 2007 02:15 PM
dopey11
LS Series Tech
Aug 24, 2006 11:55 PM
