Pulling codes on a 93 Z28
Old 10-17-2007 | 11:18 AM
Billdo38's Avatar
Default Pulling codes on a 93 Z28
How do you read the codes on a Pre 95 car?
Old 10-17-2007 | 11:25 AM
95slvrZ28's Avatar
Default RE: Pulling codes on a 93 Z28
You'll probably have to go to a Chevy dealership for the '93, they're different from all the other 4th gens in that they have a Memcal chip instead of a reprogrammable PCM, most Advance Autoparts or Checker or whatever you have near you only read OBDII cars with their scanners.
Old 10-17-2007 | 11:50 AM
Billdo38's Avatar
Copy that. Isnt there a way to use a paperclip on certain pins in the connector under the dash, and just count the flashes from the SES light?
Old 10-17-2007 | 06:05 PM
95slvrZ28's Avatar
I'm not sure about the Camaro, I know on my friends Subaru that is OBDI there was a variety of different connectors under the dash that you can connect/disconnect and you could count the SES light flashes, but I'm not sure about the paperclip thing.
Old 10-17-2007 | 06:58 PM
The paper clip trick won't work in your car. You car had an OBDI PCM with a OBDII diagnostic connector. You need a OBDI scanner with an adapter to plug into the OBDII connector, or you can use some jumper wires in place of the adapter.
http://shbox.com/1/xraycable.jpg
dkn920
11-05-2012 07:12 PM
Gorn
07-22-2011 04:55 PM
tipdrip215
02-01-2010 04:04 PM
cbrenn71
10-07-2007 08:11 PM
Quick Reply: Pulling codes on a 93 Z28
