Pull engine?
Old Nov 16, 2012 | 04:40 PM
JakeYeah's Avatar
Default Pull engine?
Do you have to pull the engine to add headers to a 96 z?
Old Nov 16, 2012 | 06:51 PM
Failed Devices's Avatar
Nope. Jack it up high in the front, and you can even jack the rear up as well for a better angle.
Old Nov 16, 2012 | 07:30 PM
should not have to but you can also loosen the k member and drop it a bit if needed, dont have to unhook much. allot depends on the manufacturer/style/shape.
Old Nov 16, 2012 | 07:52 PM
JakeYeah's Avatar
Alright. Anybody got any links for any headers for a good price?
Old Nov 16, 2012 | 08:15 PM
torque_is_good's Avatar
a certain poster who is very near and dear to me made a thorough write up and craby was kind enough to sticky it at the top of the 4th gen
https://camaroforums.com/forum/lt1-l...4th-gen-58225/
Old Nov 17, 2012 | 12:14 PM
TheArtfulLodger's Avatar
Depends on the type of headers you're looking for. Do you want Long-tube? Mid? Shorties? If you're not sure, do a little bit of reading, and then just ask the all-knowing google to find some for you.
Old Nov 17, 2012 | 06:43 PM
Old Nov 17, 2012 | 07:02 PM
jkeaton's Avatar
Jakeyeah, where do you live?
Old Nov 17, 2012 | 07:03 PM
jkeaton's Avatar
I wish that write-up had pics.
Old Nov 18, 2012 | 06:39 AM
you'd use your lunch if you had to look at me. Oh, not those kind of pics.
it's really pretty straightforward to do the job and thus why is was descriptive
The most difficult thing is realizing that they call it "modification aka mods" for a reason
so the collector does in fact touch the drivers floor plan= if you don't like it, get a hammer and modify the floor pan from underneath
so the 3 inch cat back is difficult to get aligned and bolted onto the new y pipe= 6 foot pry bar and there you go.
But those are basics not specific to header installs
honestly, since it's such a pain in the butt to gain access the best advice is about the header gaskets. Don't go cheap and use what comes with the header and don't fall for "name brand" of Felpro.
You do not want to re-visit the job of the gasket thus why I strongly encourage Percy's. Sure they will cost you $30 or so but you would gladly pay $100-$200 to just make the exhaust leak go away after using the other brand of gasket.
