programming key fob?
Old Feb 1, 2012 | 02:46 PM
Niteblaster's Avatar
Default programming key fob?
Anybody know how to program a 94 camaro? I tried pulling the radio fuse and doing the on/off 3 times in 5 seconds but it doesn't work? Mine worked about 8 times when I first got the car and then wouldn't work again and I have replaced batteries 2 times and tested it at Autozone and it lights up on the display when I use it.
Old Feb 1, 2012 | 04:10 PM
BasicConcepts's Avatar
Technical User
you need to take a peice of wire find the access data link beside steering column connect g and a together the locks will lock and unlock programmimg is in active mode then touch and hold down any button on you remote for 15 sec the doors will unlock and lock your done.
Old Feb 1, 2012 | 04:28 PM
Thank you very much. After i push the remote button do I just unplug the wire from G to A and will anything else need to be done to get it back out of program mode?
Old Feb 1, 2012 | 04:51 PM
Technical User
nope just pull the jumper wire out and your good
Old Feb 8, 2012 | 08:07 AM
androzer's Avatar
If the car doesn't include a wireless entry system
dose connecting A & G leads to the locks will lock and unlock?
cause I have after market and I want bring the original fobs, want to make sure that I already have this option.
Old Feb 8, 2012 | 04:02 PM
JGuy07's Avatar
Gna sound like a dumb question, because this is. But, what actual size batteries go in these key fobs? Mine has never had batteries in it and I haven't bothered to get them, so just wondering.
Old Feb 9, 2012 | 05:23 PM
androzer's Avatar
no it's not there is hell of sizes and look of batteries like coin
good question and I am ready to hear an answer,
I put the car on ignition and connected A with G and nothing happend!
Old Feb 9, 2012 | 05:47 PM
Technical User
check your rpo codes and look for "AU0" thats keyless entry... its possible you dont have it even if you have power locks
and the batterys are 2016
Old Feb 22, 2012 | 06:15 AM
I finally got around to trying to re program my key fob. I did the jumper wire from a-g and the locks cycled 1 time but then nothing happens when I push any button on the fob. I have replaced batteries twice in the fob also. It did work when I first got the car for about a week if I was very close to the car but nothing now. I tested the fob at autozone to see if it lights up on the tester and it would barely light up. Could it be my fob is bad or is something else wrong?
kdm212
Oct 16, 2009 09:54 AM
Phil 2001
Jun 27, 2008 10:48 PM
96ss1557
May 3, 2007 01:53 PM
tyler2497
Apr 11, 2007 10:43 AM
kender
Sep 27, 2006 09:10 PM
