pressure test
pressure test
so i pressure tested my coolant sytem and it held 18 psi. my engine is still overheating and i tested for a headgasket and i know i dont have it blown. i do see some leakage/old oil buildup on the passender upper side intake gasket area where the alternator should be could this be messing up my coolant system? idk 100% that it is leaking but i do see some kinda old oil/sludge around that area.
i am unsure if the fans are coming on when the engine gets hot, i have purged all the air out i am sure of that. brand new thermostat.
well when it overheated it blew out the overflow tank, pressure tested and found out i had a leak in my radiator. so i replaced, now i have a brand new one and its still overheating and it holds pressure now.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
