Is this a Precursor or a Sign of a Transmission Problem looming in the future?....
Old 08-05-2018, 06:11 PM
CamBigCat's Avatar
Originally Posted by craby
motor mounts are tough, hard to bust, i have seen them sag and let the engine drop a bit, enough to make my 7qt pan hit the steerting rack just enough to feel it on my steering.
Thank you Craby.
Yes, they would probably need a sledge hammer to bust loose. Thanks again.
Old 08-06-2018, 08:45 PM
CamBigCat's Avatar
It's a broken trans. mount.
I returned today from a shop that does only transmission repairs and drive train problems with that diagnosis.
They quoted it at $150 even though they had it replaced 3 years ago, they did not offer a lower price or a warranty
I will have it done for $130 at a repair shop that I am super loyal to for $130.
I will save up to replace the motor mounts since the tech said if the motor mounts are as old as the trans. mount, the motor mounts should be replaced also.
If the motor mounts should be replaced soon, they do not seem like it -- opening the hood and looking at the engine bay the engine does not rattle back and forth from side to side so that's good news while I save up to replace motor mounts to nip problems in the bud.
Thanks again every one.
Old 08-06-2018, 10:31 PM
Y2K's Avatar
Y2K
Y2K is offline
I'd keep your lead foot out of it 'till you get those motor mounts done.
CamBigCat
08-04-2018 03:54 PM
emailname
07-26-2015 12:08 AM
ksink7
01-11-2014 05:55 AM
94ChevyCamaroV6
10-01-2011 11:44 AM
Spartan66
11
12-08-2008 02:59 PM
Quick Reply: Is this a Precursor or a Sign of a Transmission Problem looming in the future?....
