Powermaster starter wiring question.
I went back and looked at the schematic again and found that I incorrectly stated the relay coil and its contacts were not electrically connected. The 12V source is the same for both, but the only way replacing the starter could effect the relay coil that I see, would be by creating a voltage drop while cranking that was large enough that the coil no longer had a 12V supply to energize it. If this was the case, I think you would at least hear the solenoid kicking in and out.
I'm not hearing anything when I try to start the car. The security light comes on as soon as I turn the key. I've got a VATS delete system, just not installed yet. I think I'm just gonna order a 96 Corvette starter and put that on there.
