power windows
Old Aug 21, 2023 | 09:29 AM
camaroguy65's Avatar
Default power windows
Once I hit 100,000 miles my power windows have stopped working. Possibly overheating as it works again a bit later. Looking for help on repairing the window motor.
Old Aug 21, 2023 | 08:02 PM
Both windows or just the driver's side?
Both may be a problem with the body control module,just driver's side may be a bad motor.
The window motor can be had in a kit but the BCM is obsolete,you will have to either pull yours and send it in to be redone( eBay guy) or get one from a wrecking yard and try it or send it in then replace yours when it comes back.
Old Aug 21, 2023 | 11:26 PM
check fuses. check for power to switches and track either way.
Old Aug 22, 2023 | 06:28 AM
Knowing the year would help since not all 4th gens even have BCMs.
Motors are a very common issue for these cars and the first one you do will be a bear. I knew a bodyman that used to mess with 4th gens and he said he could go to a u-pull it lot buy a door with a working motor and paint it and replace it on the car faster than he could switch the motors.
Old Aug 22, 2023 | 07:18 PM
Right,I just had the driver's side replaced in my car,it made it 96K miles and failed.
Old Aug 30, 2023 | 05:26 AM
twisTy23's Avatar
Try one of these...
Old Aug 30, 2023 | 05:27 AM
twisTy23's Avatar
Old Aug 30, 2023 | 06:31 AM
Having a manual is always a good idea and you can down load many of the original factory manual in PDF format for free. Check out the Manual sections on this sight.
As a former GM Master tech there are some jobs are a bear even when you know exactly what to do. Many mechanics come up with their own process that works for them. I can remember hating doing rack and pinons in the old Cavalier even after doing a half a dozen of them I hated doing them. The guy next to had a bunch of tricks and could do them in half the time I could but he had done hundreds of them.
MaxTheKiing
Aug 23, 2010 03:21 AM
andkrs7
Dec 18, 2008 02:02 PM
therat324
Nov 27, 2008 07:34 AM
1980rscamaro619
Jan 10, 2008 07:09 PM
broozer
Jun 29, 2007 10:57 PM
