Power Window slow
Old Sep 8, 2020 | 03:55 PM
Blackrag's Avatar
Default Power Window slow
Is there a known problem with late Gen 4 power windows running slow or in my case sometimes just stops 3/4 of the way up ? If so , is there an easy cheap fix. ?
Old Sep 8, 2020 | 07:48 PM
HenryC's Avatar
Try spraying some silicone lubricant on the inside of the rubber guide rails if there's not a fabric like material between the rubber and the window, the rubber can get old and in some places start to stick to the window causing it to have a hard time rolling up or down.
Old Sep 9, 2020 | 08:26 AM
Blackrag's Avatar
Thanks I'll try it. Sound like the lub will get on the glass though.
Old Sep 9, 2020 | 12:01 PM
HenryC's Avatar
Yes, a small amount will, if you really don't like having a little on the window but it works well after you spray the silicone on you can buy new rubber guide rails, just a cheap thing to try first
eric forman
Jun 23, 2014 09:43 AM
sfrick
Jul 28, 2010 09:30 PM
guardian1816
Sep 28, 2009 12:24 PM
therat324
Nov 27, 2008 07:34 AM
Shifty
Feb 19, 2006 04:20 PM
