Power steering whine
Old Aug 31, 2010 | 12:15 AM
i think you can get rebuilt rack from autozone or napa.
Old Aug 31, 2010 | 08:40 AM
torque_is_good's Avatar
once again the man with the 4 bolt is correct. It's items like this that I just replace. It's not worth it to try and rebuild yourself unless you have a service lift and all the tools
http://shop.advanceautoparts.com/web..._1301236968___
Old Aug 31, 2010 | 12:18 PM
adamgh81's Avatar
My 99 only has 56k miles, I don't want to buy this part if it's not needed. Any ideas on how to make sure it's what I need?
Old Aug 31, 2010 | 03:48 PM
personaly i would look to the pump first. are not that costly. i dont know why or how the rack could make the pump whine when not turning the steering.
Old Sep 1, 2010 | 02:50 PM
chewybacca11's Avatar
Did you bleed the system after you installed your pump?
Old Sep 1, 2010 | 03:03 PM
Bleeding it is a thought, but after 500 miles you would think the air would have bled out well before that. A p.s. system is self bleeding, so all you have to do is turn the steering wheel left to right a few times, full lock to lock (with the engine running of course).
Old Sep 2, 2010 | 01:57 AM
Yeah that's what I'm talking about. When I replaced my engine crossmember I had to take out the rack and pinion. My repair manual told me how to bleed it and this is basically what it said...
1. Fill the reservoir to the correct amount and let it sit for at least 2 minutes
2. Start the engine and run it for 2 or 3 seconds only and then check the reservoir and add fluid as necessary.
3. Repeat those until the level remains constant.
4. Raise the vehicle so the wheels are off the ground.
5. Turn on the car and rev to 1500 RPM and turn the steering wheel from stop to stop and keep checking the fluid level.
6. Lower the car back down and while the engine is still on, drive forward enough to achieve full right lock and then full left lock. The reservoir will be foamy from this so let the engine stand a few minutes and then repeat the previous operations.
The book says that this may cure a noisy pump so give it a try... It wont hurt!
rs657f
Jan 9, 2015 08:13 PM
uncontrolledchaos
Jun 22, 2011 04:37 PM
shane1617
May 22, 2011 08:35 PM
bohuntr
Oct 15, 2009 09:22 PM
ChevyBoy16
Feb 7, 2007 02:41 PM
