power steering fluid
On my 02 SS it is always wet around the power steering fluid filler cap, is the cap just not sealing and I need a new one? Anybody else have this issue before. It never really seems like it is going down tho and it has always been at a good level. But the mess always comes back so im not sure what to do.
^^^ probly the gasket failing or gone. if the fluid level is to the upper full mark when its cold then it may be expanding when it heats up and overflowing. might try keeping it at the lower full level. also clean it up good and see if it is in fact overflowing and not making its way out a crack or break that you can not see.
Make sure not to overfill, use the markers on the little dipstick attached to the cap, Check level when fluid is hot. Overfilling will cause the oil to push out through the cap as it expands. Also make sure you are using the recommended type of fluid, and that it does not foam when it gets churned up by the pump.
