Possible Fuel Pump Issues
Old Mar 20, 2012 | 06:16 PM
Nick12110's Avatar
Default Possible Fuel Pump Issues
'94 Camaro Z28 LT1
My car was showing signs of fuel pump failure (little power under acceleration, poor idle, engine dying while driving, ect.) I put in a new fuel pump and the car ran very well with no issues. Drove around town and ran great with no power loss. Stopped at the gas station and filled the tank up full. Bam. Right back to no power and dying. What could've possibly caused this? Im stumpped.
Old Mar 20, 2012 | 06:51 PM
did you look to see how clean the tank was when the pump was changed. try pulling the fuel filter and dumping its contents out in a clear container. dump the filter from the tank side. see whats there.
Old Mar 20, 2012 | 09:47 PM
Nick12110's Avatar
The tank, pump, and filter are all brand new.
Old Mar 21, 2012 | 12:22 AM
have you tested the fuel pressure? could be a plugged cat. does the car have catalytic converters, are they getting red hot, does it seem quite?
Old Mar 23, 2012 | 05:27 PM
Nick12110's Avatar
Found the problem. The seal around the top of the pump assembly wasnt set right and there was a vacuum line that was sucking in fuel, dumping raw fuel into the engine, causing it to not run.
Timebender
Mar 30, 2014 09:46 AM
H2C
Jul 2, 2012 01:54 PM
steve634
Oct 27, 2011 06:39 PM
Chaos99
82-92 V8 Tech
Aug 15, 2011 09:17 PM
mdwj
May 9, 2010 04:54 PM
