Please help with CPS...
Old Jan 27, 2011 | 04:35 PM
bonezz's Avatar
Default Please help with CPS...
I just tried doing a search on this but not much luck..My crankshaft positioning sensor is bad. I think I can replace it without too much trouble. Has anyone done this or know a thread where it is explained? Oh yeah I have a 96 z28. The guy I bought it from said he put in a engine with a firehawk block...idk, I figure its still a Lt1 so it still takes the same cps. any help much appreciated. thanks.
Old Jan 27, 2011 | 05:49 PM
mab6680's Avatar
its not that hard to change one bolt take it out put new one back in and put bolt back i have a 97 z28 vert with the 30th package 80k on the car 30k on the motor the guy i picked it up from was fed up he kept getting a code for the cps couldnt get the cel out changed the sensor 3 times he kept buying cheap parts from pep boys they only listed one sensor turns out when i called my local parts guy he found ac delco listed two cps one for the coupe and one for the vert diffrent part numbers no clue why but he kept putting the one for the coupe long story short spend the xtra money and get the acdeco part 67 dollars and havnt had a problem since
Old Jan 27, 2011 | 06:46 PM
Clean the harness connections at the sensor before buying a new one.
Considering it's vulnerable location, crud in the connection could be a factor over it being an actual sensor failure.
Old Jan 27, 2011 | 08:52 PM
The CPS in your car does not affect engine performance, it's only purpose is to detect misfires. Could be that the previous owner replaced the engine with an earlier model one, like a 95 or older LT1, which did not use a physical CPS, and the PCM is setting a code because it can't find one. Could be the previous owner is BS-ing about changing the CPS. Check the front cover.
Old Jan 27, 2011 | 10:09 PM
heres a front cover for the 96-97, see the part sticking out towards the bottom, thats where the crank sensor goes.
Old Jan 28, 2011 | 11:20 AM
bonezz's Avatar
Thanks for the advice! One other question, how do I get the service eng soon light to go off? Will it go off if I fix the problem? IE new cps or clean it up..
Old Jan 28, 2011 | 11:31 AM
If you fix the problem the light will eventually go out. If you don't fix the problem it will stay on, or come back on even if you clear the codes with a scanner.
Old Jan 28, 2011 | 01:52 PM
sebi1990's Avatar
You can go to most of the mechanics and ask em to scan it and afterwards ask em to reset the cod
