please help with cam issue (z28pete?)
Old Nov 13, 2008 | 05:03 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: please help with cam issue (z28pete?)
you could easy go around .530 for lift.
but try to keep your duration a little smaller. 211 or 218 are probably good lift numbers. i dont know if they makea 224 for you, that could be a little more aggressive one.
Old Nov 13, 2008 | 06:52 PM
cbr600rx7's Avatar
With the 230/244 valve springs are going to be a must but i think you already know that. I normally dont like aftermarket rockers on daily drivers due to the valve chatter but they may be a good investment if you are dead set on this set up [>:]. Personaly i would have gone with somthing like spec suggested but maybe just a little higher with a 218/224 0.495 int./0.503 exh 112 lsa for a mean street cam with fair idea and a mean sound.
Old Nov 13, 2008 | 07:24 PM
Ninja Administrator
well, im a big fan of lift.... but i drive an ls1 so maybe im biased
I dont see why springs will be necessary with duration. you could have a 360duration cam (well..... u cant.... but u see what im gettin at) and as long as the lift doesnt bind the spring youre good. That being said, its my opinion that new vavles are a part of any new cam swap. even on a little baby cam I would change out my stock springs. they are usually designed to only take daily driving with the stock cam. hell, even if u wanted to regularly drive your car hard on the stock cam it may be a good idea lol
cbr.... have u like doubled ur posts in the last couple weeks??? werent u around 600 when i did the star change?
Old Nov 13, 2008 | 07:33 PM
cbr600rx7's Avatar
No i have been slow on here the last few months. In fact when the star change accrued i had just over 1000.
But this is good advice even with a hot cam its good to upgrade your springs. This is a big cam for a bolted LT1 and would not have been my first choice but it will sound like a beast.
On a side note what cam are you running spec.
Old Nov 13, 2008 | 07:57 PM
Ninja Administrator
232/234 595/598 113lsa
but to the OP, im an ls1, our cam stock is much larger than many SBC cams. and this cam has pretty poor low end torque, definite high revver.... i cant even imagine what .640 lift on a lt1 would do lol. that car would be drooling on itself
Old Nov 13, 2008 | 08:12 PM
cbr600rx7's Avatar
As shown in my sig i run 228/234 114 with .605/.605
But for your car that is a huge cam. I dont know how street friendly she will be and you are going to loss a noticeable bit down low. You are going to need to get the car up in the power band to get the most out of here so a good stall and good rubber to get that power to the ground our a must.
Old Nov 13, 2008 | 08:18 PM
Ninja Administrator
talking to me or the OP?
im hoping to tune some more torque into it. hopefully the driveshaft comes in tomorrow and the shop can start tuning it. also with 4.10s going in it will definitly help me get into the power band.
your cam has alot of duration for a FI cam. does it have blower ramp rates? mine is a tsp cam so, while they arent as steep as fi cams, it has some pretty steep ramp rates which i like for the nitrous.
Old Nov 13, 2008 | 08:31 PM
cbr600rx7's Avatar
Yes i was talking to OP about his monster lugger .
Old Nov 13, 2008 | 08:56 PM
Ninja Administrator
....... ur sarcasm has earned u a new memeber tag
MWAHAHAHAHAHA
eh.... maybe not right now...... forum is acting up
Old Nov 14, 2008 | 01:27 AM
  #20
95slvrZ28's Avatar
To the OP: You're motor isn't going to last long because you're going to have some piston/valve interference problems. Motors with screwed up valves don't work very well
To the Comp Cam question: The lift on that cam looks good to me, you don't have to run a cam that has the same intake and exhaust lift. I agree with Spec, you may have gone a little extreme on the durations.
To all LT1 Guys: Don't try to target LS1 lift, you'll end up screwing something up (most likely, unless you have a lot of time, money and calculations into your motor).
