Phone Holder
Old Mar 25, 2013 | 10:14 AM
jkeaton's Avatar
Default Phone Holder
Anyone use an actual mount or holder? What are you using/where mounted? I currently put my ohone in the ash tray compartment (removed ash tray obviously) but sometimes if I hit a bump, it falls down inside. I was looking at the kind that plug into the lighter but those would interfere with my shifter...maybe something I can just bolt to the passenger side of the console or something? I installed an additional 12 volt outlet inside the console for the charger, I just need a convenient place for a holder. I dont want a window mounted suction cup or a vent mounted one (too flimsy).
Old Mar 25, 2013 | 03:53 PM
MKCoconuts's Avatar
I use the cup holder for mine and I have a Droid 3, so it's a decent size phone. Works well for me at least.
Old Mar 25, 2013 | 04:05 PM
jkeaton's Avatar
Yeah, I had a droid that fit in there pretty good, but just got assigned an iphone from work. Sumbich disappears every time I go around a corner or hit a bump...lol
Old Mar 25, 2013 | 04:21 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
Do you have it plugged in charging or just loose? I put mine in the little hole next to the lighter
Old Mar 25, 2013 | 05:06 PM
androzer's Avatar
put it in the cassettes place. by the way the 95 - 96 have an extra power output under the cassette box.
Old Mar 25, 2013 | 07:03 PM
jkeaton's Avatar
I tried in the cassette place but it comes flying out when I take off from stop lights. I want something that clamps it in place somewhere. I'll let you know what I find.
Old Mar 25, 2013 | 07:18 PM
9434V6's Avatar
i remember seeing a bass controller **** that was screwed onto the center console right where your right knee would be, just actually on the center console since most all of our knees are probably up at the steering wheel. lol. It basically was a plate that was screwed on, and on the bass controller **** was another plate. you slid the bass controller **** onto that plate. it was about half an inch, had enough tension that it wouldnt move, and they just set together. it couldnt go down, only up.
so i imagine if you get a cheap phone case for it, you could do that same basic idea. put a slider on the back of the phone case and a catch on the center console. no problem.
Old Mar 26, 2013 | 04:35 PM
jkeaton's Avatar
Here's what I cam up with. I found a cheap holder that is spring loaded. I trimmed the ash tray opening so it would fit inside and then used fiberglass resin to "glue it in place and seal it in. The top still closes completely when the phone is not in it. Works great.
Old Mar 26, 2013 | 05:16 PM
9434V6's Avatar
not a bad idea. ill probably get to making cell phone holders for driver and passenger alike once im done the more important stuff. first i need a $160 dash pad so it looks good and "luxurious" from the start. haha
Old Mar 30, 2013 | 01:01 PM
libertyforall1776's Avatar
shevrolay
Nov 23, 2010 04:08 PM
MusicMan
Jul 16, 2009 03:32 PM
