performance chips?
Old 09-30-2007 | 04:17 PM
SYDEWAYZSS's Avatar
Default performance chips?
I have a 00 ss with 3:73 gears on it so the speedometer is off by like 10 mph. Does anyone know whats a good chip for that, Ialso wantit for more performance?
[IMG]local://upfiles/10050/BC493D5D70F945918A52813A6175FB66.jpg[/IMG]
Old 09-30-2007 | 06:38 PM
blackz87's Avatar
Default RE: performance chips?
you need to reflash your ECM for the Gear change, No chips in 2000Camaaro.
Old 10-01-2007 | 05:52 PM
SYDEWAYZSS's Avatar
oh realy....yea wheni took my car to the dealer to fix the gas gage, i asked the guy there about the speedometer and he said that i would have to get an aftermarket chip for that. So if i dont need a chip what do i need? do you know?
[IMG]local://upfiles/10050/2FFC81235F2A4137A14844E54000399C.jpg[/IMG]
Old 10-01-2007 | 06:30 PM
blackz87's Avatar
ORIGINAL: SYDEWAYZSS
I would be taking my car to a different Dealer, 4th Gen cars do not have removal chips in the ECM. Find some one else to reprogram the ECM.
Old 10-01-2007 | 07:01 PM
You can spend $400 on a hand held programmer such as Hypertech, or get your PCM tuned for your mods and gear changes from a tuner such as PCM For Less, and get a better tune and save some money
Old 10-02-2007 | 04:22 AM
SYDEWAYZSS's Avatar
so is this a good deal for the Hypertech programer?
Improve your vehicle's power and performance in just minutes with this smart, under-dash programmer. It even lets you specify which grade of gas and aftermarket accessories you use! Read More
Priced at $289.95
Old 10-03-2007 | 07:55 PM
It is OK, but it is limited to what they (Hypertech) have programmed, and may not meet the needs of your car if you have many mods. It is good for gear changes and tire size changes, and if you have a car that is basically stock.
Old 10-04-2007 | 03:06 PM
jthorn9's Avatar
Well I know a programmer can be used to flash the ecu to the new gear size, but they also make speedo gears that can be used to correct the speedo after a gear swap. Now granted, this is on Fords, but I'm sure Chevy used something similar. They're not 100% exact, but come in fairly close. I have 3.55s (up from 2.73s) with a 23 tooth speedo corrector and my MPH is only off by aboout 1.5.
wcijames
2010+ V6 Tech
02-12-2011 08:28 AM
Chevy101
01-29-2010 05:06 PM
jeb
02-12-2009 11:56 PM
Camaro_Boi69
09-03-2008 01:36 PM
mrdillon
01-28-2008 08:11 PM
Quick Reply: performance chips?
