Parking Brake Cable Guides
Old Jul 18, 2009 | 05:24 PM
Racer's Avatar
Default Parking Brake Cable Guides
95 Camaro 3.4l
There appears to be 3 parking brake cable guides on the rear. One of which is attached near the RR shock mount, or on the shock mount I guess is correct.
The other 2, one on each side, are just loose. I can not figure for the life of me where these should be mounted.
Anyone know, or have a picture? I downloaded that PDF parts diagram, while it shows the guide and bolt, does not show where it goes.
Thanks!
Jeff
Old Jul 18, 2009 | 09:00 PM
disk or drum brakes?
Old Jul 18, 2009 | 09:07 PM
if u can see it this is for a 93
Old Jul 19, 2009 | 06:36 AM
Racer's Avatar
Thanks. Yes its drum brakes.
I can't quite tell in that pic, but it looks like they are bolted to the rear end housing cover?
Old Jul 19, 2009 | 07:30 AM
Racer's Avatar
I figured it out. Apparently someone who had the car before me must have changed the rear cover gasket and didnt realize there are 2 longer bolts. (Which may be why it was a little moist around those longer bolts)
Anyway, I appreciate the pic. That helped a ton. Now no more clunking from the parking brake cable when I hit a bump.
Grizmo
Jan 23, 2015 10:01 PM
hkunz
Oct 10, 2010 07:05 PM
th3po1son
Nov 29, 2008 01:50 AM
85z285.0
Apr 19, 2008 10:22 AM
