Painless Wiring Harness
Old Jul 12, 2017 | 12:11 AM
Steverino's Avatar
Default Painless Wiring Harness
In the event I don't find a 97 Z28 manual trans engine wiring harness I might have to shell out the big bucks for something like the Painless Performance sets. Anybody have experience with these custom types? do the powertrain control module plugs and all the sensor plugs, and injector connections match up? Oh yeah, this is a base 6 cyl manual tranny car we're putting the Z28 K member motor and tranny in.
Thanks
Steve
Old Jul 12, 2017 | 11:59 AM
95 camaro 406's Avatar
your doing a swap ,you better have a good wireing guy ,so if i read this right your puting a lt1 engine an trany in a v6 frame ,going to be lots of mods + how is the computer going to work ,you need to put this projects section ,an post alot of pictures ,i honestly dont know,or think it will work out as you will need to strip the v6 car ,what about the rearend ,mabey someone else knows more ,but most time with these swaps there a mess with the v6 cars alot of work ,now if you had z28 car to put the engine it all different
Old Jul 12, 2017 | 12:27 PM
Steverino's Avatar
thanks 95 Camaro now I don't remember what my question was.... oh yeah I asked about the painless wiring harnesses.... I don't know... we do this crap all the time we already updated the motor to obdii we have the k member and the computer this is actually one of my smaller projects
Old Jul 12, 2017 | 12:28 PM
It all depends on what year the V6 and what you know about programming a PCM.
You can get aftermarket harness to run the engine. The problem will be what's going to run the rest of the car. On the 97 the PCM runs the ABS/Anti theft system/gages /body control module. The body control module controls just about everything else, AC- heat-windows, door locks.
One advantage of the 97 is if you have an automatic harness you can program out the automatic trans control and run a manual trans.
The 97 wiring is complete different from a 94. There is a chart that shows everything needed to swap V6 to V8 but we need to know the year of the V6.
Edit:
Make sure you read this carefully The W on the very bottom is the one you want to avoid. It just says all wiring. That will triple the work needed. For what bodies are selling for I would sell the one I had and buy one that matched the the engine I had. Heck you can find 97 Z28 with bad motors for $600-700 then its a weekend project. There are tons of threads on converting auto to stick.
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
BlackRat
Dec 11, 2012 10:34 AM
fitman
Aug 8, 2011 06:35 PM
8182z28
Jul 24, 2006 02:25 AM
FieroFanatic
Apr 28, 2006 02:00 AM
68RSSScamaro
Nov 15, 2005 04:22 PM
