P1516 code please help
Old 09-16-2017, 06:28 PM
Robert Jelinski's Avatar
Default P1516 code please help
Intermediate problem code p1516 throttle actuator the car will start acting erratically sometimes if I'm idle throw the code and if I turn it off and back on a min later everything is fine. I'm thinking it's the throttle body. 2000 camaro 3.8. 166000 miles. Also has surging problems when ac is on or when coasting between 25 to 35 mph also makes me think maybe the throttle body any input helps thank you.
Old 09-16-2017, 06:58 PM
check wires to the tac module, check plug and plugin for loseness, damage or water. last replace tac module.
Old 09-16-2017, 07:24 PM
Thank you for response I've checked the wires wiggled them and everything while car is running nothing happens runs like a champ
Corvette_Mike
LS Series Tech
12
11-24-2014 06:10 PM
apcamaro
09-01-2011 12:55 AM
hevymetalg
09-28-2008 07:50 PM
hevymetalg
09-15-2008 07:58 PM
Quick Reply: P1516 code please help
