P0410 code- likely problem?
Old Jul 28, 2008 | 06:12 PM
martybaker's Avatar
Default P0410 code- likely problem?
For the past few months, I've had a Service Engine light, cause by code P0410- Secondary Air System Malfunction. I know there can be a few reasons for this, but in general, is it usually the air pump itself that goes bad? This of course is assuming that all hoses, fuses, connectors, and check valve are good. A Camaro guy that came to buy my used seats told me that it is usually the pump itself. I wanted to run it by you guys and see what your experiences have been.
Old Jul 28, 2008 | 08:42 PM
Default RE: P0410 code- likely problem?
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors theO2 sensorvoltages, and the short-term fuel trim values for both banks of the engine. If the AIR system is operating correctly, theO2 sensorvoltages should be low, and the short-term fuel trim should be high.
If the PCM determines that theO2 sensorvoltages for both banks did not respond with the expected results during the tests, DTC P0410 sets.
What it really means that the AIR system is not working: bad pump, blown fuse, clogged or leaky plumbing, electrical problems.
Corvette_Mike
LS Series Tech
Dec 13, 2014 09:16 AM
je1058
Jun 20, 2013 07:49 AM
saskdan1
Mar 22, 2013 05:55 AM
JordanT
Apr 1, 2010 10:36 PM
Rylie
Aug 29, 2008 04:59 PM
