Oil Presure droping?
Old Sep 27, 2010 | 05:45 PM
sebi1990's Avatar
Default Oil Presure droping?
little problem is that when i stop on a red light or a stop sometimes the the oil gauge starts moving from left to right just a bit and then the car starts to shake a little whats might be causeing that problem?
Old Sep 27, 2010 | 08:06 PM
I think what you are seeing on the gage is a result of the shaking not causing it. Oil pressure drop the lower RPM it can drop real fast once your idle goes below 700 RPM. Fix your idle issue and I think your Oil pressure will be fine.
As to what is causing your shaking or bad idle there are a lot of things that can cause that. Bad gas, Leaking EGR valve, Tired IAC. Almost all your normal tune up stuff ect.
Old Sep 27, 2010 | 08:15 PM
sebi1990's Avatar
ok cool thx i'll c because the previous owned didn't realy tok care of the car that much and the overflow coolant was all gone when i check it and the oil is realy black im going to get on it right away
Old Sep 28, 2010 | 11:26 AM
change oil, new plugs, check plug wires and replace if lookin bad, check air filter and change if needed and scann for trouble codes.
marten
Sep 3, 2012 11:26 AM
dopez28
Nov 13, 2011 04:25 PM
GSLcustoms
Mar 22, 2011 10:47 AM
3.4LUV
Mar 6, 2006 02:34 PM
