Oil Pressure Problem
Old Apr 23, 2009 | 03:46 PM
Saint_Ali's Avatar
thats what ive always been taught,granted it was by a ford master technician...
Old Apr 23, 2009 | 08:46 PM
I am not following the logic. If I take a 350 with a 180K that has 10psi at idle and i put a high volume/high pressure pump in it I will have higher oil pressure. This will help get the oil up to the valves and it will help the motor to last longer. Sure the bearing are still worn and will fail at some point but a engine with good oil pressure at lease has a chance of working. Once the oil pressure fall below 10 psi per thousand RPMs you will damage parts quickly.
Old Apr 23, 2009 | 08:47 PM
Tonylig928's Avatar
it should say what oil you should use probably 10w30 i like Mobil 1 personally, i can't really help you on this problem because i kinda have the same problem. trying to figure it out. this weekend is "work on my car weekend"
sorry
Verdes8891
Sep 29, 2012 07:20 PM
rokinv6
LS Series Tech
Mar 4, 2010 01:06 PM
meniscus
Apr 6, 2008 12:49 AM
98ss4REAL
Jun 28, 2007 06:47 PM
dealsndaytona
Aug 16, 2005 12:40 PM
